Thank You Bob. I have now verified that I have the correct coil. The swather will run fine for about a half an hour, then will chug and sputter. We have gone through the points, condenser, plugs, plug wires, dist cap, rotor, coil, and carb has been gone through (float, needle valve and seat checked). Fuel sediment bowls and screens are clean. Tank has been drained and re-filled. Fuel shutoff solenoid on carb is working and fuel pump is not very old. Have been running 10% ethanol. Once it acts up we wait about 25 minutes and it will re-start fine and run for another half an hour. I'm now wondering if the gas in the metal lines is boiling and causing the problem. Any ideas? Thanks in advance.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
