Re: 210 IH Swather Coil
Posted by Janicholson on August 07, 2010 at 18:54:20 from (67.72.98.45):
In Reply to: Re: 210 IH Swather Coil posted by LonM on August 07, 2010 at 15:21:40:
Three ideas:
Check the fuel cap on the tank to assure it is vented.
Check the coil when it quits to assure it is not way too hot to touch (it can be hot, but not boiling hot.
Put split rubber tubing on the fuel lines to buffer some of the heat away from the steel.
Jim
