Farmall H charging problem
Posted by Russ Moore on August 07, 2010 at 16:31:17 from (67.255.17.217):
I have just (almost) completed a 1 1/2 year restoration on a 1951 Farmall H. This has a distributor w/battery and voltage regulator. I put on a new generator(stayed with the 6 volt), a new voltage regulator a new wiring harness and also new heavy battery cables to go with the new battery. Being naive, I hoped all would work upon assembly. The battery doesn"t seem to be charging. I did polarize the generator and follow the wiring diagram to a T.
The one thing I do notice is that the light switch is a 4 position which I think in the early tractors was also a manual control for charging. Any help to diagnose the system would be appreciated. I"m not up on these systems.
Thanks for any help
