Posted by bkpigs on August 17, 2010 at 18:06:32 from (75.132.223.199):
Ok, so I think I screwed something up tonight. I changed the points on my 41 B because it had a slight miss. I could not start it afterwards. Took off the wire cap (distributor cap if it had a distributor) and went in to re-check the gap. After seeing the gap was not the problem I decided to look into the oiling hole for the gears that are between the cap and the points. Seeing it was jambed with dried grease I decided to clean it out.
I put the gears back together with the notched tooth on the smaller gear lined up between the L and R stamping on the larger gear (is this correct???? It was the only logical thing I could think of). Still no luck starting it.
I went to check the spark by pulling the "supply" wire from the cap and holding it by a spark plug. No spark!!! What could I have screwed up by changing the points?????
Sorry for any typos, I have been dealing with a split open finger on my right hand. Makes it hard to hit the right keys.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
