It sounds to me like the pilot bearing on the mainshaft is worn enough and/or corrosion damaged and the cause of excessive noise. Popping out of 4th is what leads me in that direction.
You can remove the belt pulley or cover plate in 15 minutes and find out what you've got in there. Once off you can put your hand in and see if there's noticeable play between the mainshaft and the input shaft. Also you can determine what level of corrosion damage from the moisture. Sometimes the get a little surface rust on the gears and sometimes a lot and sometimes not at all.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
