Re: What were the large frame engineers thinking in the '50s
Posted by RPM1941 on August 23, 2010 at 18:52:42 from (173.25.70.110):
In Reply to: What were the large frame engineers thinking in the '50s posted by Wardner on August 23, 2010 at 15:12:42:
I can believe they might have driven it from bottom, however this would have limited the interchangeability as the H-300-460 had a standard belt pulley mount, they took the same mount gasket, same goes for M, SM-SMTA, 400/450, & 560 all had same opening and matching gear internal with same mount flange gasket, probably cost was factor also as the gear access from the bottom on H/M-SM was not there. I worked for IH then CASE-IH dealers for 47 years in service & parts.
