Posted by Duanes on September 16, 2010 at 12:34:34 from (136.234.40.2):
We have a Farmall Regular that has hot spark and feels like it has good compression. Tractor ran with original E4a mag and died when it got hot so, I assumed it had a bad coil and switched to A F4 that I had as a spare and had been tested. Hand cranked tractor and it started and ran but, was running hot and backfiring so, I figured the timing was retarded and after running a few minutes I shut it down. Before changing timing I tried to hand start and no success,pulled it and started and died. Pulled again and nothing and blew oil out of air cleaner. Put new coil in mag as someone suggested and will only pull start and we ran 5 minutes and it ran fine but, will not crank start. Any ideas what is wrong.?Anyway to check compression? Old timer I took it too says he feels like the compression is good but knows of no way to check with out starter. Thanks for any help! 9/16/10 New Post: Still have not solved the mystery. Will low compression cause the tractor to not be crank started? Is there a way to test the compression? Thanks
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
