Re: IHC 400 Radiator
Posted by Do it now on June 19, 2000 at 22:49:06 from (207.177.47.155):
In Reply to: IHC 400 Radiator posted by Rich on June 19, 2000 at 10:51:13:
Rich- Replace that bearing while you got it apart. Mine cost around thirty bucks. Seemed kinda steep, but on one hand "they got you" and on the other be glad parts are still easy to get. Recommend loading the bearing cavity with gun grease while you're in there. At least give the worm screw and big gear a generous coating. It's probably been 50 years since they last got any and might be another fifty 'till they get another lube job. Now is the time to replace all hoses and belts... Jest grit your teeth and do it man. Hang the old ones on the wall as "emergency spares" and you'll probably never need 'em! You can cut up an old radiator hose and use it as the cushion under the re-built radiator. Cut two big diameter washers, one on top of the other, for each bottom mounting bolt and the steering shaft hole should line up just right when you cinch it down. Good idea about trying for a tank parts junker radiator, posted by The Red. Another trick I did was cut away the bottom of the fan shroud, then cut the rest into a left and right hand piece, with a pre-drilled connector plate at the 12 o'clock position. Let me know if you're up for the "time machine and killer team" project I've been advocating. Good luck, IHank
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
