Several points to make: The big coiled flat wound spring should be the return spring for the drive. This spring is pretty heavy, and connected with two bolts into the drive collars. The little spring is not a return spring. No driving force is put through the spring, the drive force is only in the spiral grooves. The little spring is a noise reducer, keeping a little tension on the pinion gear when retracted.
Farmalls in the Letter series, and X00- X50 number series. never used a starter with a solenoid engagement. The X00-X50 series used a starter relay, but it did not pull or push linkage to make the drive move on its shaft.
The clutch type starter drive is way different, it uses a ratchet style one way clutch in the moving part of the drive. Ebay item # 150502997216 is an example of what they look like. They solve many issues particularly jamming. they also have a little spring, but it works.
It operates similar to the type 1, but the internal one way clutch allows the tractor to overrun the drive.
The worn drive on yours is binding at the flywheel and has gotten all the value out of it.(opinion) don't mess with it it is toast. Jim.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati
... [Read Article]
Latest Ad:
[More Ads]
