Posted by dpski on October 28, 2010 at 05:38:09 from (128.222.37.58):
Argghhh..... Please tell me it"s just air in the system and it will work it"s way out.
Finally pulled the starter rod on my Super C last night after months of work. It was a happy moment to hear it run again, except to my surprise the hydraulics are not working. This project started with a leaky radiator, months later and countless hours later of preparation, paint is dry and ready to put the wheels back on.
Of all the things I disassembled, fixed, and re-assembled, to many to list here, you guys know the deal, the hydraulics were the least of my worries upon startup, because all I did was disconnect the FastHitch hydraulic lines. Already rebuilt the hydro pump last fall with new O-rings 'cause it was leaking into the crankcase. Drained and refilled the whole system and cleaned the screen as well last fall. All was functioning just fine when I shut it off before this project started.
I topped off the hydraulic fluid, been using Case/IH Hy-Tran. I worked the levers, both the TouchControl and the remote FastHitch cylinder lever back and forth a bunch of times. Took the TouchControl hydro unit filler plug out during all this hoping to see some fluid movement and/or let any air in the hydro unit escape, nothing.
I greased all the TouchControl arms before painting because I didn"t want the paint to get in-between them and bind them up.
I"m at a loss for all I disconnected was the remote FastHitch lines and the rods from the TouchControl levers. The hydro unit, pump, and metal tubes to/from pump to hydro unit remained intact during all this.
I"ll try it again tonight and hope it"s air stuck in the system, but anything else I can try or check?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
