Re: Farmall H Hydraulics
Posted by Janicholson on November 03, 2010 at 18:47:31 from (67.72.98.45):
In Reply to: Farmall H Hydraulics posted by WDR84 on November 03, 2010 at 17:48:10:
You should feel a load on the engine and minor vibration in the tractor. The clutch must be engaged (not pushed down) for the pump to work.
The front elbow on the left, and the right elbow are both connected together inside, so a lift cylinder can be hooked, one to each side.
Pulling the lever out all the way is raise. In the the stop, is hold. Lift and push farther is lower.
The pump is driven from the trans. Thus the clutch must be rotating the trans for hydraulic to work.
It is one way as it is, thus only one hose is connected to each cylinder (unless you use the top half of each cylinder for additional fluid storage. If so a hose is connected to the pump drain with a T or cross, allowing the top ports of the cylinders to connect to the reservoir.) The reservoir takes fluid to the notch in the dipstick. (under the cap) If none, between 9 and 7" from the top of the fill pipe will be full enough.
The left rear port is a delay port, and mostly not used today. Jim
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
