Re: wrong sleeves in arebuild kit?
Posted by El Toro on November 10, 2010 at 12:05:15 from (108.3.200.96):
In Reply to: wrong sleeves in arebuild kit? posted by Sam Eubanks on November 10, 2010 at 10:25:09:
You may the have 354898R1 block used in some of the Super A's and Super C's. The sleeve diameter at the seal was 3.3125" on the A's, B's & C's and were 6.875" long. I think some of the Super A's used the same sleeves. The later Super A's and Super C's used sleeves that measured 3.4375" at the seal and were 7.060" long. You need to measure your old sleeve diameter at the seal and the length. Hal
PS: You still should be able use an overbore kit
to boost the cid to 123. If you have the Super C block you can boost that to 133cid with 3.250" sleeve/piston kit.
