12 volt conversion
Posted by Jim iowa on November 19, 2010 at 07:39:34 from (67.142.172.20):
My H has been converted to 12 volts neg. ground.it has a 12 volt coil marked use with external resistor only.it has a resistor between the coil and the distributor.a mechanic friend says the resistor should be between the ignition switch and the coil.whitch is right? thanks. Jim iowa.
