Re: bn will not start
Posted by old on November 26, 2010 at 09:35:17 from (4.245.11.215):
In Reply to: Re: bn will not start posted by TODD HECK on November 26, 2010 at 08:52:51:
Well it may have been engaged but when it started the end part which maybe broke has now moved so the starter can not long work at all. Seen it happen more then once and it is not good if it does happen. Only way to be sure is pull the starter out which is a simple 2 bolt thing
Today's Featured Article - Buying your first tractor: The People You Buy From - by Chris Pratt. If you are a first-time buyer, chances are that you are likely to take the word of the seller on things. This is where the problems start... You have reviewed your implement needs and determined the size of machine that will fit the bill and even made a list of the most desirable models. You checked on the availability of a 3-point hitch for the machines on the list and advertised in your local classified paper with so ... [Read Article]
