Re: Another electric ? for experts or anyone.
Posted by Bob M on December 18, 2010 at 15:00:40 from (67.240.171.41):
In Reply to: Another electric ? for experts or anyone. posted by D Slater on December 18, 2010 at 13:02:08:
Alternators are inherently self-limiting for current. Even with the output terminal dead shorted to ground an alternator will not provide more than rated amps as stamped on the case.
And a #10 wire carrying 42 amps may get a bit warm but it won't melt/burn even with a 42 amp alternator at full load.
However your #10 wire COULD melt/burn should a short develop at the ammeter or wiring between the battery post and the ammeter. The battery could send several hundred amps thru the short which will quickly melt the wire.
Fortunately a short like this is not likely - but it is possible...
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
