Re: Steering pump leak 1086
Posted by Bob on December 25, 2010 at 13:17:05 from (69.178.228.68):
In Reply to: Re: Steering pump leak 1086 posted by Fixerupper on December 25, 2010 at 12:29:33:
"The booster gets oil from a tee that's tapped into the return line coming out of the pump."
Been a while since I've worked on one of those, but there's GOT to be a source of oil to the clutch booster other than "steering pump return".
You rebuilt the clutch booster... do you suppose an "O" ring could have failed?
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
