300 won't free wheel
Posted by Farmall Dann on January 06, 2011 at 15:33:34 from (96.60.16.231):
Traded for a farmall 300! It would go in gear but would not come out of gear with out using a lot of force. Did not matter where TA was. Adjusted main clutch adjusted TA clutch no change! Tractor will not roll in netural! Will not roll with clutch down. Pulled top TA cover rocked tractor TA jumps up and down. It act like its in gear. What bearing, or shaft ,or ?? is the cause of it locked ? Thanks
