706 update and new issues.
Posted by Lee Wilson on January 15, 2011 at 17:46:08 from (75.221.134.124):
I was able to find the plug that lies in between the plugs for the finals- I had to pull the draw bar to see it. The plug was stripped out and froze in, so I drilled it out, and tried to easy-out the plug. Broke the easy out off in the plug. Was able to blow away enough of the easy out and heat the plug enough to get a 1/2 inch extension in the recesse plug and weld it in place. GOt the plug out, replaced hyd filter,new plug and filled her up w/ hyd oil. No hydraulics, no steeriing, lift and front end loader wont raise. I pulled all 3 drain plugs to make sure oil was there, and it was. The steering wheel turns way easy, so Im guessing theres not oil, and may have an air lock. Any of your expertise would be appreciated!
Lee
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
