Re: No oil pressure.
Posted by CNKS on February 11, 2011 at 18:06:19 from (216.144.104.128):
In Reply to: No oil pressure. posted by CNKS on February 11, 2011 at 15:01:40:
Can someone tell me if there are any plugs behind the front cover -- I do not think I left any out, but it is one place to look -- although I have to remove the front end, again.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
