Posted by CNKS on February 12, 2011 at 08:03:58 from (216.144.104.128):
In Reply to: Re: No oil pressure. posted by El Toro on February 12, 2011 at 07:51:49:
The machinest gave me all the plugs in a box, not saying I got them all in. The pump end plate and spring have been replaced. The valve or spring socket has been out and is not plugged or anything. I have not removed the drive gear and pulled the shaft because I saw no need to, perhaps I should. What I would like to know before I take everything apart is if there are any internal plugs I may have missed. Gene Bender says there are none in front, which will save me from removing the front axle, etc, and the pulley and front cover. If there is one behind the front cover it will not leak externally. I prefer to take Gene Bender's word for it as he has been in there many times, me only once.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
