there could be two marks on the flywheel, one for full advance and the other for TDC. The rumor is that they are both very obscure and need drastic finding. Put a thin blade screw driver in the #1 plug hole and hand rotate the engine till the #1 piston pushes the driver up until it is 1/2 inch from fully up. Mark the driver and the front pully of the tractor (or a gear if it is apart), with a felt tip pen. Then turn the engine till the mark on the driver returns down to that same spot. Mark the pulley again. then rotate the engine to 1/2 of the distance between the pully marks. Now you know where TDC is located on the FW. It is done with mechanical stops in the plug hole to be very precise, but not needed to just find the mark. Jim
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
