Anything that locks up the engine and has its origin in the trans needs to be tended to before operating. I, however, would start the engine. Starting it now can eliminate that whole end of the tractor. Block down the clutch so it cannot put power through the trans. If nothing else it will put 45% of your mind at ease. (maybe 65%) the next step is to analyze the trans. Some components can be seen through the belt pulley mount (or plate if your lucky and do not have a pulley drive on it) looking for damaged gears and or bearings out of place or showing wear metal or grief. I assume it was in neutral. As such it will have the constant mesh gear in action driving the counter shaft, and the intermediate bearing (between the input shaft and the output shaft), as well as the front bearing in action. If nothing is found, and even if it is, it will probably require taking off the trans top to fix it. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
