Setting carb on M
Posted by Baelee05 on March 17, 2011 at 13:59:24 from (166.137.140.133):
Well I finally got the M wired up and got my governor problem solved. Now I am having some trouble getting it to throttle up smoothly. I rebuilt the carb so maybe I don't have something set correctly. I was told to turn the idle screw while at idle until it starts to sputter and then back it off a half turn. Same procedure with the main screw at full throttle. The idle screw I had turned in tight and it didn't pulled down and the main screw at full throttle was almost all the way in before it started to stumble. It runs real nice at idle and once it stutters and stammers it's way through it runs good wide open. It is a magneto system with brand new 3116 autolite plugs and plug wires. Any suggestions? Thanks guys.
