Thanks, I went out and played with it a little tonight. This tractor has a valve to select the 3pt or the remotes. If I raise the 3pt and then switch to remotes, the implement does not drop. So I would assume this would rule out the piston. Which I think leaves two other possibilities, the pump or the spool controls(right?) Either one more common?
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
