Re: H Carb, RustyFarmall
Posted by pete 23 on March 31, 2011 at 10:54:46 from (74.44.100.190):
In Reply to: H Carb, RustyFarmall posted by GordoSD on March 31, 2011 at 08:00:02:
Rusty Farmall, do you know the correct main jet size for a farmall 300 gasoline. Also, did they ever use the throttle shaft with a slot for the economizer circuit on that model. Friend of mine brought in a carb that had been worked over with some drill bits.Also has a brass plug inside bowl to economizer circuit. Can't remember if that is factory or not. I have a new jet for a 460 that I know is close but not sure exactly. I found a idle jet that is correct. I sure wish IH or somebody had a chart of all those carbs with the jet sizes, main jet, air bleed, nozzle tip size and the air bleed hole sizes and spacings etc. I have good manuals on the later tractors but not those below about a 656 or so.
