Re: Farmall h starting problem again
Posted by glennster on April 03, 2011 at 06:34:40 from (99.90.9.153):
In Reply to: Farmall h starting problem again posted by Farmallboy15 on April 03, 2011 at 06:23:10:
assuming a distributor and not a mag, set points a .020 open at the widest point. remove coil wire, replace it with a spark plug wire and a spark plug laying on the engine so it has a good ground. turn engine over till points fully close. with battery power to the coil, remove distributor cap,rotor and dust shield. with a small screwdriver,manually open and close the points. you should see a small spark at the points, and the coil should be firing the spark plug.
