Posted by Albo5000 on April 11, 2011 at 18:56:40 from (68.14.16.225):
I just bought a 53 Super C. It was last used two years ago and it will not turn over so far. when I pull the starter lever the engine will crank very slowly. Battery is mostly charged, 6v, 593 cold cranking amps. Also floods carb.
Additionally, when connected to 12v battery via jumper cables tractor cranks a lot harder but will not turn over. When connecting 6v battery with provided cables, cranks slow. When connected to 6v battery via jumpers to the starter, starter winds up like toy motor but will not crank engine.
I am definitely going to rebuild carb but i want to get tractor started first. Also going to replace all the hoses, belts, plugs, wires, distributor, and eventually rewire the entire electrical system.
What should i do to try and get her running? Is it worth it to re-wire as a 12v system?
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati
... [Read Article]
Latest Ad:
[More Ads]
