Worth the 12v Conversion? and couple other ????
Posted by Fullers Farmalls on April 12, 2011 at 12:11:09 from (158.83.127.89):
As many of you know i just got a Super M and it has a 12v conversion. Starts in under 2 seconds of cranking. My 44 h takes for ever to start. Sometimes 20 to 30 seconds. plus messing with the carburetor. Which needs rebuilt as it leaks gas like no other. Would appreciate some input as to what to do about the carb. Finally if i go with 12v what alternator should i look for from the junk yard? as to make of car or will they know when i ask? My tractor has a magneto will this affect the conversion? Finally Can i use the existing wiring harness or should i update it?
