Fix the carb first and see if that helps the starting issue.
If you use the 10SI GM 3 wire alternator you have to run the wire from terminal 2 on the alternator to a switch with a light or diode in line. Don't have to do anything with the Mag. A GM one wire will just hook up to the Amp meter. If you flip the generator mounting bracket over it can be used as the bottom alt bracket.
If you old wiring harness is in really good shape you can reuse that. If not rewire it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
