Re: Re: Re: Re: Re: Re: Re: Hey Red...CUB Engine Noise...Need Further Advice
Posted by George Willer on July 29, 2000 at 10:43:05 from (205.133.30.91):
In Reply to: Re: Re: Re: Re: Re: Re: Hey Red...CUB Engine Noise...Need Further Advice posted by george on July 29, 2000 at 09:55:24:
George...from another George,
While you still have the pan off, I would remove the bearing caps to look directly at the bearings, looking for pulled metal.
Also, with the caps off, you may be able to get an idea of piston and piston pin condition by looking for any twisting movement. With a strong light, look carefully at the cylinder surface...piston slap can leave its mark.
I hope you find that all is well.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Hey Red...CUB Engine Noise...Need Further Advice
