Re: 1952 Farmall Super A engine shuts off
Posted by d beatty on May 04, 2011 at 15:34:14 from (71.239.246.137):
In Reply to: 1952 Farmall Super A engine shuts off posted by Jim Linville on May 04, 2011 at 08:32:12:
You say your useing ethanol. Ethanol is corrosive. E10 is more corrosive than E85. It is hard on older rubber & plastic . It could be effecting some of those parts in carb..
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
