Re: 706 engines
Posted by Allan In NE on May 10, 2011 at 08:04:21 from (148.66.88.254):
In Reply to: Re: 706 engines posted by The tractor vet on May 10, 2011 at 07:25:39:
You're mixing apples and oranges.
Compare that gasser to its diesel counterpart. Ya really have to go some to shove 2 gallon an hour thru those things.
Allan
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
