Farmall Tractors Discussion Board
Re: Help with front pulley
Posted by Todd Markle on January 04, 1999 at 19:18:27:
In Reply to: Help with front pulley posted by Stan(VA). on January 02, 1999 at 04:00:27:
Stan, You may see my later post on this-I mentioned to use a harmonic balancer installer to
put the pulley back on(should be available at any
parts store or tool dealer). If your crank isnt
already drilled and tapped, get it tapped to match
the installer. The installer has an arbor that threads into the crankshaft and has its own threads. It uses a large nut and a thrust bearing
to pull the pulley on. This puts the stress on the puller threads instead of the threads in the crankshaft.
Post a Followup
: Re: Re: Help with front pulley
