Re: Cub Fires on Exhaust Stroke
Posted by equeen on June 01, 2011 at 15:54:07 from (209.102.248.55):
In Reply to: Re: Cub Fires on Exhaust Stroke posted by Jim Becker on June 01, 2011 at 12:07:53:
Smart and this Gene aren't often used in the same sentence when I'm tinkering with my tractors.
Okay, I aligned the notch on the front pulley with the pointer. (Then I removed #1 plug and peeked - yep, piston at top, both valves closed just as it was when I used my slow, trial-and-error method.)
So, my problem is with what I'm doing with the distributor. I'll work on doing it better per instructions. (I was thinking at the time that things happen in fractions of a second, but that it may take a longer fraction of a second for the spark to reach the cylinder, thus the spark should have occurrec by this moment; not later than this moment.) Is this why we "back up" the distributor just a tad?
Thanks.
