Re: H won't make rated speed
Posted by big a on June 17, 2011 at 05:55:39 from (166.225.135.78):
In Reply to: H won't make rated speed posted by big a on June 16, 2011 at 20:54:25:
Actually, I just had distributor off, and freed up the advance. Inspected points and regapped them.
I attached the spring over the pins that held the original governor spring, and was able to get enough tension that way to get my 1815 hi idle speed, but it will not idle correctly this way. Spring pin holes are not worn.
