Re: Farmall 300 Carburetor - Replacement
Posted by rustyfarmall on July 13, 2011 at 05:41:14 from (216.248.71.224):
In Reply to: Farmall 300 Carburetor - Replacement posted by Kevin Rapes on July 13, 2011 at 05:29:34:
Kevin Rapes said: (quoted from post at 05:29:34 07/13/11) Thank you for the sarcasm. I honestly had spent quite a bit of time searching google for this. The predominant results that came up were for carburetor repair kits (which I do no need). And unfortunetly when I searched this site, I was under the wrong section (under Farmall 300 parts and not carburetor). And would it occur to you I was seeking advice on what people recommended the most? Obviously there is a big price difference between the carb on this site and the one on Bates. Maybe one is better? But anyways, thank you for patrolling these forums and the sarcasm. If you didnt like my post you didnt have to respond. I knew there is a reason I dont post on here.
Kevin, I'm pretty sure there is no such thing as a "new" carburetor for a Farmall 300, and if there was, the price would be closer to $600. That $300 price someone mentioned would be for a professionally rebuilt original carburetor, and even THAT price is a bit on the high side. A Farmall M carburetor will work, but will not be 100% correct.
This post was edited by rustyfarmall at 05:44:31 07/13/11.
