756 questions
Posted by CDB on July 21, 2011 at 18:47:07 from (216.229.21.13):
I have some questions about my "67 756 gas that I bought last year. It ran a little rough when i bought it, so I tuned it up. It still runs a little rough at idle, but seems to smooth out with more throttle. My mechanic says it is a burnt exhaust valve. I"ve run several cans of Seafoam through it...seems better. How can you tell if a valve is burnt? Is there some simple checks? If it is carbon build up, is there a better way to loosen it?
Also, the TA is out on the low side(I swear it was working when i bought it) and the clutch is adjusted as far as it goes to get the right free play. Do I need to replace the clutch right away? It doesn"t slip and I only use it to push snow and do light acreage work.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
