For whatever reason some blocks that failed and were replaced by IH dealers have the casting # ground off. Sometimes a number is hand stamped in. Not sure thats what you have, the absents of a engine serial number and the presents of a small plate on the block with 2 retaining bolts behind the carburetor is a indication it could be. Also a dipstick or a drilled hole with plug at the dipstick location. None of these is a positive indication of a replacement block though. Although absents of a engine serial # is pretty good. Would help if the block casting date can be located, most times its near the same level as the ground off # and on forward. Original M blocks don't have C248 on them, some replacements do. Think a casting number for a regular M block or a replacement ending in DG is a little older than your tractor. Date code would tell. Engine could be in the parts system and still end up in a later tractor though. Engine could also be from a power unit.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
