Re: Farmall H Tranny noise
Posted by farmallhal on August 04, 2011 at 15:20:28 from (71.49.67.203):
In Reply to: Farmall H Tranny noise posted by matt1983 on August 04, 2011 at 14:54:52:
Does the noise appear any time the clutch is released? How about neutal, reverse, all forward gears - yes, even 5th? If the noise is not present when in 5th it might be the transmission pilot bearing inside the transmission and this might be the bearing you are trying to describe in the back end of the transmission input shaft. The noise created by a worn transmission pilot bearing USUALLY is not present when in 5th as the input and output shafts are locked together for a direct drive off the engine in 5th. Hope you understand this and if you have access to a parts catalog or service manual you can see this in detail, Hal.
P.S. Please post back your findings as we can all learn something from your situation, thanks.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
