Re: Finding TDC of compression stroke when no help available
Posted by old on August 12, 2011 at 08:30:56 from (209.86.226.61):
In Reply to: Finding TDC of compression stroke when no help available posted by Duanes on August 12, 2011 at 08:23:06:
First off can you see the piston with the spark plug out?? If you can then pull the valve cover and watch for the piston to be up top. When it is up top and the valves are both closed your at TDC
