When you want power to your Gresen, pull the Liftall lever back while operating the Gresen. The Liftall valve will stay there unless the hydraulics meets a heavy load. Or you can pull the lever back, rotate the locking clip on the reservoir, and not worry about the Liftall kicking out. You can run all day or all year like that.
The Liftall lever on the reservoir is single acting. Middle position is neutral, back is power, forward is to release any fluid in a cylinder via gravity down.
Yep, I always run triple valve banks on my Liftall live hydraulics. I have three tractors like that. That permits three circuits with pressure on either side of the piston in the hydraulic cylinders. Or forward and reverse in a hydraulic motor.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
