Re: Farmall M removing pully's in the front
Posted by Bob M on August 16, 2011 at 19:14:17 from (69.207.87.100):
In Reply to: Farmall M removing pully's in the front posted by John Lundberg on August 16, 2011 at 18:54:12:
John - First remove the big nut that holds the pulley on (it's a 2-1/2" hex). Then simply pull the pulley of the front of the crank.
Usually the pulley will slide off by hand - no puller required. However it's wise to have a suitable gear puller on hand just in case(!)
