Re: H starting problem
Posted by Wyokid on August 20, 2011 at 15:35:41 from (72.36.61.157):
In Reply to: Re: H starting problem posted by Janicholson on August 20, 2011 at 15:28:06:
Carb bowl is filling. Just took out the new condenser and put back in the original, same thing- start, run 2-3 seconds and die, wait 5 minutes start run and die.
