If you're testing on a cylinder you're sure the valves are closed on, and you've got some oil in there - and you're only getting 30/40/50 psi then you're certainly leaking somewhere. at 60 you're starting to come into the "ok" range.
Somebody here mentioned that you need to let air IN to the cylinder in order for it to give you the full reading - that is true.
But if you're in doubt at least get it to it's max compression level, hold it there and watch to see how long it takes for the compression to drop.
If it stays steady for a long time, you may have less of a problem than you think.
If it does go down steadily - I agree with the other person to check the head gasket first. In doing so you can get a much better feel for the situation looking at the valves and the cylinder walls.
30 - 60 is a fairly big range. Does that mean one is at 30 and another at 60? Just curious.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
