Re: Front seal. Another stupid novice question.
Posted by El Toro on August 29, 2011 at 07:05:03 from (108.3.225.100):
In Reply to: Front seal. Another stupid novice question. posted by scatter on August 29, 2011 at 06:08:08:
third party image
Napa sould have the new seal and you install it the timing gear cover. You need to look at the hub surface on your pulley for a worn groove from the old seal. You may need a speedi-sleeve to cover that area. You should should use a split bearing separator behind the pulley so you don't damage the pulley. Some of those pulleys are hard to remove like a press fit. You may need a puller like BigDog made for his Cub using a bottle jack or hydraulic ram. Hal
