Re: Farmall M problems still
Posted by JRSutton on September 01, 2011 at 19:26:44 from (75.130.109.233):
In Reply to: Farmall M problems still posted by tripleccattleco on September 01, 2011 at 19:11:40:
I wasn't clear on one thing - is it running better while choked? or not?
If it does run better while choked, you're most likely not getting enough gas through the carb, into the engine.
Did you take the carb apart, or just soak it?
You need to pull it apart and clean out the passageways with a thin wire.
