Re: New idea loader pistons
Posted by Janicholson on September 02, 2011 at 20:56:37 from (96.24.99.126):
In Reply to: New idea loader pistons posted by jtbartlett on September 02, 2011 at 19:28:26:
If that style cylinder gets pressure at the ram end, and not the cylinder (lower) end, it cannot be two way. There is no method for getting oil through the ram, then back to the ram side of the cylinder unless there were two drilled passages in the Ram. The second hose might go the the other cylinder. Just an observation, I do not know for sure. A single acting valve must be used in an open center system on a one way cylinder. Some valves are designed to be switchable between single and double acting. Jim
