B414 Hydraulic/Hitch Issues
Posted by JohnWyrwas on September 18, 2011 at 15:58:52 from (96.63.15.215):
Hello.Any help would be greatly appriciated.After searching for someone to fix the Hydraulics on an International B414(even the dealer),nobody in the area seemed to know anything about these tractors,I decided to tackle it myself.I replaced all o-rings and main cylinder seal(went off a parts breakdown diagram).When I started the tractor up everything seemed to work great but when I put the bush hog on,it will "hick-up"(drop down a bit and lift back up) Quite fast.If I close the valve off it will stay at that height without a problem.Al the controls seem fine.I am just not sure where to look next,as I said I am a novice going off a parts diagram and any help would be appriciated.
Thanks
John
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
