Re: M/Super M Gear Shift Levers with single or double bends
Posted by scotc on September 25, 2011 at 04:52:32 from (75.226.204.101):
In Reply to: Re: M/Super M Gear Shift Levers with single or double bends posted by lblock on September 23, 2011 at 17:58:02:
I believe what people refer to as the different "stages" of the SM were simply the old parts being used up and being replaced by the new ones on the assembly line.
Mine's a hermaphrodite according to everyone here. Belly pump, with underseat battery. I keep getting told it should have the battery under the tank or live hydraulics. I know it came out of the factory this way because my grandmother bought it new late in 52.
Having the old style seat with the battery under the tank simply tells you it was made earlier in the production run.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
