Re: charging system farmall m
Posted by pete 23 on September 28, 2011 at 11:45:21 from (74.32.234.149):
In Reply to: charging system farmall m posted by NORMAN MOYER on September 28, 2011 at 10:56:09:
The resistor does no take the place of the cutout. It controls the rate of charge and is hooked in series with the field windings. If you have original style cutout , it has a resistor mounted on it that was for tractors with starter but no lights so therefore had no light switch. Permanent low charge when hooking field to resistor. Arm terminal on gen to arm terminal (gen) on cutout. Battery terminal on cutout to ammeter, field terminal on gen to ground for high charge and to resistor for low charge.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
